whould mating a pull style clutch to a push style trannie work? i know they are both hydro, but will taht work? or would I just need the TOB from the pull style to adapt it (which i DUH already have off of mine!). im thinking that just the depth of the bellhousing is the only issue.
tell me todd
the pull/push clutch
It’s a whole (clutch) thing. You need the transmission, clutch slave, clutch arm, throw out bearing, hydraulic line, clutch pressure plate, clutch disk, maybe flywheel, matching rear diff ratio.
Todd Erickson
Total Performance Center, Inc.
"Todd the tuner. Can he tune it? Yes he can!!!"
Servicing the Minneapolis MN area.
Todd Erickson
