Principle behind cryo treating is kind of like the opposite of tempering which is the controlled heating and cooling of a metal to give it desired properties of toughness. However with cryogenic treating the material is taken down in temp then brought back up to room temp to achieve an additional measure from that provided by heating and cooling. This treatment for metallics is pretty much reserved for carbon based steels which exhibit phase changes at different temp levels. Aluminum does not undergo the type of granular structure realignment found in certain high alloy steels so many of the aluminum Suby engine parts will not realize a benefit from the process. Inquiring minds can learn more at the websites below
Cryogenic Society - broadbased general info on all cryo topics
http://cryogenicsociety.org/index.html
300 Below Cryogenic Tempering Service - specific applications including motorsports
http://www.300below.com/
Larry Witherspoon
Supplier Quality Specialist
Military Transport Aircraft
Aircraft & Missile Systems
McDonnell Douglas Div
The Boeing Co
larry.d.witherspoon@boeing.com
principle behind cryo-treating
Josh Colombo
Larry,
Thanks for the extra info on cryo treating!
josh
josh
