5 speed info
Should I get another tranny or change the one i got?
Poll ended at Tue Jul 01, 2003 1:06 am
yes?
4
100%
no?
0
No votes
Total votes: 4
max boost
5 speed info
Post by max boost »
I bought my 94 legacy turbo a couple of months ago, i bought it with the tranny out of it.
I picked the car up cheap(500 canadian), because the original tranny was out of it. The original tranny was seized, but the guy had just bought another 5 speed for it and was trying to save money to get some one to put it in for him. anyway i picked it up and i just bought a clutch (ACT) and i was getting it already to put back in and then i noticed that the clutch fork was different its a cable system mine is hyd, can i just change the housing so my hyd system will fit and so will my clutch that i just spent a ton of money on or should i just look for another tranny??
The car is worth it its sports sedan fully load aswell
The turbo tranny and n/a legacy trannies are different. Not to mention different gear ratios. So unless he got a 5spd tranny from an early impreza with 3.9 gearing, you're going to need another tranny.
ciper
Post by ciper »
Or another rear differential.
4.11 diffs are pretty common.
max boost
Post by max boost »
i have the rear diff that it came with thats not a problem. I just found out my machanic friend is going to try to swap the housings this week i will let u know if it works
max boost
Post by max boost »
:D
The tranny swap worked, it was super easy.
but i was just woundering if there was any strength issues now?.
