Sorry for the interruption BC-BF owners,
Robert Faulkner (Subaru2 group)and 2.5L 2000 and newer owners,
I read several weeks ago about R. Faulkners problems with his car:
poor paint upon delivery and also what sounds like ( valve chatter)
engine piston slap.
My 2003 Baja got piston slap after 2000miles of use, I also have a
noticeable engine vibration at idle after proper warmup. Vibrations
much worse at the passenger side of engine. Engine seems out of
balance. I sense vibrations by pressing on the front ignition wire
rubber boot on the side of head. Factory Rep, Ed Luksic, says my car
is normal. I don't believe a word he says. Has anyone in this group
tested or own 2000 and newer 2.5L Subarus?
Could you describe your piston slap?
Can you sense engine vibrations as I have described?
Who else has piston slap out there?
Engine vibrations at idle?
Robert Illan
1993 Legacy 5spd 133kmi runs great. Wish my Baja was as good.
illanrob@juno.com
Piston slap engine vibration at idle survey; reply to:
Josh Colombo
You may want to check out the ultimate subaru message board for more info. There's been some recent posts about it. http://pub1.ezboard.com/bultimatesubarumessageboards
gessner17@aol.com
I have a 2001 Legacy GT, 30k miles on it, It has piston slap.
Matt
Matt
