Somtimes while driving it stated to act funny backfiring and hesitade on rpm 1000 to 4000 but ok above, them often after 10 to 15 min all was ok again.
Then 4 weeks ago it happen again and didnot go away, backfiring, hesitate and thick black smoke from exhaust, so i tryed to fix it. started by reading the CEL and got code 22 (Knock sensor) so i borought one but no difrence. so then i check timing , cleaned Airmass censor, got new sparkplugs BOSCH super4 (25$)and new Bosch spark plug wires (60$)
checked all conections in engine room and to the computer,
checked wires and mesure sensors (Trottle,Airbypass,Oxygene,and more) well all i could find. the dealer told me it was the OXE sensor so i got a new one (190$) I got another alternator, and somthing i think is called sparkgenerator (somthing to do with the ingnition) but no difrence
The car war running really rich so i talked to dealer and he said the injector simply couldnot malfunction ok i mesure fuel pressure before filter and after it was 2,5kg that should be ok but the presure fell down almost imettedly after i turn swich of. so i pulled the injectors out and put in new O rings (8$) and woola it runed smooth or so to speak.
well no backfiring and seems ok but i thinked i messed somting up
I adjusted the idleswich and throttle to the spec but when i push the trottle its ok up to 1500 rpm then it seems to choke i have to tik the trottle to get it over 4000 rpm and then it just kicks fine, well i cant get it to act normal on 1500 to 4000 rpm no mather what.
Now im waiting to get neew Knock sensor (77$) and it wont idle if cold.
And i have presure tested evry vacum hose i can find.
i really thinked i have messed somting up (maybe damage the throttle sensor or somthing)
The dealer say its the sparkplugs and threads but i wont agre ( think he say that becouse im not using OEM) becouse the OEM is about 55$ each so we talkink about over 220$ for new OEM sparkthreads.
any got a idea about what i messed up.
sorry about my English
Greeting from Iceland
Sigkrist
Legasy Ej22 1991
Beige
