pulleys
pulleys
any body put new pulleys on? which is best and with how much gain?
I've put on a GFB pulley set, (crank, alternator, and power steering).
I definitely noticed increased acceleration across the board. No issues w/ less power from the alternator, all the pulleys are smaller so everyhting still pretty much spins the same as before.
The only problem I ran into was the number of splines on the power steering pulley. It didn't match the pump i have, but i corrected by installing a pump from a 98rs
MK
MK
1992 BC672 AWD 5MT
Ciper, I don't understand what you are saying about the bolt. Anyways, where did you get the subesports pulleys? Phone # or website? I second the thought on underdriving, power gains are miniscule from the actual underdriving and potentially hurt performance (messing with your alternator amperage and all). Having lighter pulleys is the key.
Is it true that you shouldn't have a lighter flywheel & crank pulley? Thought I read somewhere about that not being a good idea...
ya i've heard that also.I've also heard it's ok though so i'm pretty confused on the subject.just to clerify,does underdriven mean smaller around then stock?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
It means making certain pulleys turn slower. This can be done by making different pulleys bigger OR smaller. Think of a 21 speed bike and how the diameter changes in the front and back. You can get close to the same ratio with different combinations. Most try to get the crankshaft pulley turning slower IIRC and others also have the alternator turn slower also because these two use up the most horsepower to accelerate them.
If i remember correctly to get the alternator pulley out i had to keep the belt on.. or I might have used a pair if large visegrips to clamp it down too (been awhile
The GFB PS pulley i have fits loosely inside of the stock PS pulley, the alternator pulle yis maybe a few mm smaller.
I picked my set up off NASIOC (i-club back then actually) for $150
MK
MK
1992 BC672 AWD 5MT
That alternator pulley is the biggest pain in the ass to get off. We used a heavy duty chain wrench on the pulley, buggered it up pretty good, then used a 1/2" breaker bar with a good 3 ft cheater bar on it, and we still had to reef on that thing.
If you got an impact wrench, I highly suggest you use it, or if you can take the alternator to a shop that has one, it may be worth giving them a couple bucks to take the old pulley off and put the new one on.
My recommendation is just to get the crank and PS pulleys LIGHTENED and not underdrived. Especially if you are running high end stereo equip. You can find 'em on Ebay for bout 150 USD. Usualy in your choice of color(blue red silver or black). Perrin also makes a damn strong LIGHTENED Crank pully. It runs about 120 USD. Most pully systems made for an EJ engine will fit all EJ's.
Cody
1994 Legacy Ti Wagon (Estate)
2.4L of N/A fury :)
Awesome vendor: http://home.att.net/~teaguesauto/index.htm
2.4L of N/A fury :)
http://home.att.net/~teaguesauto/motor.htm
Teague's auto has the fullset, but chances are you will need teh newer pump.
MK
MK
1992 BC672 AWD 5MT
If your looking for more power, the power per $ ratio is really low for pulleys. If you want an engine that revs faster, they will do the trick. Removing the AC is a really good option because it's cheap plus you get some more weight loss of the front end. The power gain is easily found from calculations and is more accurate then a dyno test in many ways, and it turns out the power gain is low in reality. The perceived power gain is high though. A faster revving engine can be funner. Turbo guys may want to question if it's a good idea to have the engines rpms drop faster between shifts.
92ss, 66bsa thunderbolt, 92miata, 06wrx
