coolant leak while idling?
Dizzy
Post by Dizzy »
Gang -
If I let my 93 turbo idle for longer than normal (~10 min), I get a small puddle of coolant (between the size of a quarter and half-dollar) under the passenger side bank of cylinders, towards the front of the engine.
My guess is the water pump, but I'm wondering why it only does it when the car is idling. Any input would be welcome. TIA.
2004 STi
1993 Touring Wagon
you sure it's from the engine.
check the front portion of the plastic end cap on the passenger side. it's a common point of failure.
Dizzy
Post by Dizzy »
Josh -
Thanks for the quick response. Regarding:
<n00b> I'm not sure I know what your talking about here. What plastic end cap? </n00b>
Thanks.
2004 STi
1993 Touring Wagon
aluminum radiators typically have plastic end caps on them that are clamped on to the aluminum part.
Over the many heat cylces that occur, a small crack can form and leak coolant....my car had this same issue......I'll try and find a pic of it...assuming i took one.
Dizzy
Post by Dizzy »
Cool. Thanks.
2004 STi
1993 Touring Wagon
THAWA
Post by THAWA »
also the waterpump is on the driverside so I don't think that's leaking
Dizzy
Post by Dizzy »
Huh. I thought it was on the passenger side on the EJ22t. Oh, well.
2004 STi
1993 Touring Wagon
ciper
Post by ciper »
If your upper radiator hose clamp is loose it will drip collant down to the timing belt cover which will sneak around and look as if its coming from the bottom of the engine. Id check this first.
petridish38
Post by petridish38 »
here's a pic of the radiator. the place that often cracks that josh was talking about is the part outlined in red. you can see that i put JB weld on mine and it worked for about a year and a half. but if i were you i would just get a new radiator if it is cracked.
http://www.angelfire.com/alt/subaru/images/radiator.jpg
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
THAWA
Post by THAWA »
hehe that's where mine cracked :D either there or on the side facing the engine
Dizzy
Post by Dizzy »
Thanks for the pic. I'm gonna be pissed if I have to get a new radiator. It looks like the alternator may be on it's way out, too. I'm only getting ~12v from the battery terminals with the car running.
grr...
2004 STi
1993 Touring Wagon
