Has anyone tried swapping in a JDM instrument cluster?
As above, the JDM market has some different instrument clusters, and apart from the speedo and the tach being swapped.
I am in canada so the kilometre speedo is good.
So, Will it work?
Should I try?
Any feedback is appreciated
So, Will it work?
Should I try?
08 GE - SWP
96 BG - SGP
96 CX - EBP
96 BG - SGP
96 CX - EBP
ericS2the6
LegacyT
Shouldn't be a problem. But I know some Legacy's had electronic speedometers, while others had cable. Electronic ones wouldn't work. JDM RS RPM guages have a 7500 RPM redline
I want to get ahold of one of those.
Mark,
Mark,
they also have a little light next to the water temp gauge. I'm not sure if its for the water temp or the red line eitherway I want it
"Electronic ones wouldn't work"
Are you sure? To change a transmission over from mechanical to speedo is really simple. You just unscrew the cable mount and screw a sender back in.
I dont know what else is needed but Id love to get rid of the cable.
You are better off swapping for an early japan built cluster. Color changing gear indicators, sun roof open indicator, better temperature gauge "font" and so on.
same here cept i dont know what you mean by temp gauge font
If you have an early car that was built in Japan you should have these. The issue is many of the later cars where built in the US and lost alot. Let me guess you both have little white dots on your vent controls to show which way they are pointing.
Having owned/worked on many legacy I notice alot of differences. The only GOOD thing I saw with the Later built american built units is that the Wagons got black plastic speaker buckets in the rear, compared to the early japanese which had white plastic ones that crack at the mounting stud.
Weird. I have a 11/89 Japan wagon and I've got the black buckets.
Ah I see. And I just ran outside in the cold cuz now I had to know whether I had those white dots on the vents
(I do).
I work as a lot guy at a Chrysler dealership, and a new word I learned recently was "de-contenting". It seems that as a model ages, manufacturers start removing "redundant" stuff from the vehicles. This includes stuff like insulation and features like the "white dots". The new Grand Cherokees are so bad that you can actually see light through the sunvisors. I guesss that's one advantage of owning an early production model.
Rish
Rish
05/89 here
good lord thats old, yes I do have the white dots (had to check aswell
same
Were the brights infront of the car image standard on all of em? I love that little thing
You guys suck. I'd love to have that, even if it was only for the novelty.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
yeah it's really funny though, I hadn't opened the rear doors in a while, then I did and saw that light, I was like what the he...oh right, the other door
Ryan if you'd like you can come oogle at my light
Yeah they do. The only thing I don't got that you guys got is the sunroof indicator. I have the high beams and doors. My dad's old 79 GL had the door lights also. Identical to ours now. His also had the same high beams, and it even made the driveline and th wheels brown when 4wd was engaged. It turned off when it was in fwd. I always thought that was cool. Remember, that was back in 79.
2014 Volvo S60 T5
2014 Volvo S60 T5
If I fail my motorcycle permit test, I'll probably be calling you tomarrow morning to go cruise. If I pass, I may be going on a cruise with my grandfather. We'll see.
2014 Volvo S60 T5
2014 Volvo S60 T5
