We all remember how distraught I was when I found out I was burning oil. So I switched to pure dino oil to try to stop it. During the couple weeks in between the last oil change and when I parked it to do the clutch fork, I didn't lose hardly a drop of oil, through many different types of driving.
However, I'm not sure I'm out of the woods yet.
I took off every last thing exhaust related to do the tranny drop, and I found something quite puzzling on my exhaust manifolds. The manifold-to-head mating surface on the driver's side of the manifold is all black and sooty with oil. The passenger side has no such residue on it.
Now, I have some oil on the bottom part of my driver's head, surrounding the manifold and what also appears to be leaking out behind the timing cover, by the cam seal
Which of these two "possibilities" (both are kinda off the wall) do you think is correct?
1) The cam seal is leaking and the oil running back across the head is somehow making its way through the manifold gasket and getting burned inside and coming out my tailpipe. It appears that only the driver's cam seal is leaking.
2) The valve seals on only one head are letting oil through. I'm also guessing that the oil is not completely combusting and some oil spray is leaking out through the gaskets and getting the residue I'm finding all over the bottom of my head.
Both would explain the sooty substance on the mating surface of the manifold.
I find both to be strange, because oil seeping through the manifold gaskets seems stretchy, but only the driver's head valve seals also seems kinda weird to me...
I am really thinking about this, because I want to properly stop the oil leaking into the exhaust before I fit a set of new manifolds on it and ruin another good catalytic convertor. And I'm trying to make an almost 14-year-old car leak no oil
Thoughts? Comments?
