								morgie
						Post
								by morgie »
			Hi,
    What could be the best location to put a EGT probe ?
1 - UpPipe : Near the engine, but may be dangerous for turbo if anything breaks.
2 - DownPipe / Near O2 Sensor : Not so far from source, can be used to analyse O2 Sensor, Not dangerous for turbo... but readings may be lower.
3 - ???
							morgie
'98 4Runner V6 Manual 4x4.
								ciper
						Post
								by ciper »
			Neither of the two!
As close to cylinder three as possible!!!
								morgie
						Post
								by morgie »
			Hum, yeah the Evil cylinder ... but, standing in front of the engine, wich one is it ?
							morgie
								LegacyT
						Post
								by LegacyT »
			Yup. 4-6 inches from the flange on cylinder #3 (passenger side closest to the firewall)
Mark,
								ciper
						Post
								by ciper »
			You could have traced the spark plug wire (your coil pack is labeled)
Shoot for 1400 F or 750 C as your target maximum.
								RaZor
						Post
								by RaZor »
			What if the EGT is plugged on the downpipe? what reading should I get?
								Aaron's ej22t
						Post
								by Aaron's ej22t »
			a reading that is not as accurate.
							92 Legacy Turbo \ 5MT \ Silver
								ciper
						Post
								by ciper »
Or a reading that means nothing. At least the up pipe would give you an idea of combined temperature, which is also an unusual place to monitor.
Aaron's ej22t: You stole my thunder
								Grant
						Post
								by Grant »
			I figured you would do the four way from that airplane place with a sensor for each cylinder.
							Grant Hughes
Denver, CO
http://www.nocoastmotorsports.net
								ciper
						Post
								by ciper »
			Im really going to! I plan to get the larger version of the guage though, easier to read.
My current plan is to have my car turbo'd and running by august 1. Then I will install the 4 way EGT
