rear lateral link replacement
greg donovan
Post by greg donovan »
are there any other options to replace the rear lateral links w/adjustable units other than the whitline pieces?
it is for my 90 fwd it has a serious toe out problem which makes for some great turn in and rotation but is way to hard on tires for daily driving. so i want to have it possible to have o toe for street and more toe out for rallyx.
mTk
no title
Post by mTk »
There are JIC magic arms, but they are several times the $$
MK
1992 BC672 AWD 5MT
Toe is adjustable with the stock suspension.
If you alignment guy/place can't get it back into spec, something is either bent or they don't know what they're doing.
ciper
Post by ciper »
greg donovan
Legacy777 wrote:Toe is adjustable with the stock suspension.
yep something is bent. im hoping it is just the control arms. the adjustment cam bushing is at the most toe-in setting and still very toe-out. cant see what's bent though and have had 3 different shops look at it. all very competent. one a master subaru tech. i want more adjustment that i can change myself.
those jic are pretty. but too much $
ciper
Post by ciper »
You think the Knuckle could be bent?
kelley
Vendor
Vendor
Post by kelley »
I have the noltec's. they are a dream when it comes to alingment.
someday I will post pics of the rear end.
It has quite a bit of camber.
ciper
Post by ciper »
Can you post a link to a vendor?
greg donovan
if by knuckle you mean where the strut bolts up to and where the arms are bolted to i sure hope not. the car has seen alot of rallyx abuse in the last few years and has clipped a curb hard enough to tear through the outer layer of the sidewall. im sure 50mph into a rutted 180 deg hairpin probably hasnt helped either.
ciper
Post by ciper »
Bent struts that still function normally are common on WRX that have touched curbs. Maybe your strut is bowed near the top.
greg donovan
the impact happened befor i put the new gr2's on.
