rev stumbling and exhaust pops
georryan
Post by georryan »
Well here I thought I was being thorough and fixing things gradually. I did the 02 sensor, new plugs, and was still scratching my head on how I'd get hesitation and what not. I also cleaned my ground points and the battery terminals. Still didn't help at all. Then I did a more thorough inspection of my vacuum lines, and the hose to the underside of my underhood resonator is busted off. I can't believe I never saw that. So after I fix that, I'm hoping I'll get it back to were it is sapposed to be as far as hesitations, and rev stumbling.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
TheSubaruJunkie
Post by TheSubaruJunkie »
Ive noticed that my car will buck alittle but only when i get on at WOT. If i back off the throttle, it seems to solve the missfire until i can gain enough speed to use WOT.
On the old subie engines you could use Carb cleaner to find vacuum leaks... i wonder if that'll work on the EJ's as well.
-Brian
1983 Subaru GL-10 Brat
1986 Toyota 4Runner
THAWA
Post by THAWA »
Hehe, you check your wires? If you want you can borrow my magnecors for a test run when they get here to see if they cure it.
Kelly
Post by Kelly »
Be careful with carb cleaner, it will ruin old, dry rubber.
Werd.
georryan
Post by georryan »
I've got new wires, if that was directed at me.
2014 Volvo S60 T5
