Are there any option availible to cool the fluid in the 5mt? I think i read somewhere that the 5mt has no fluid pump (a feature only in the 6mt)
MK
5mt oil cooler
5mt oil cooler
1992 BC672 AWD 5MT
Yeah, the 5MT's fluid isn't pumped anywhere; the gears all just turn through it. I suppose you could add a pump to carry the fluid out of and back into the differential; I haven't seen the inside so I don't know if there's a good spot to add a pickup or not.
Are you worried about your gear oil overheating? I don't think I've ever heard of that happening on a Subaru 5MT.
http://bbs.legacycentral.org/viewtopic.php?t=15752
Motor oil. I have soem 75w90 royal purple gear oil.. but so far the 40w has been excellent.
MK
MK
1992 BC672 AWD 5MT
Hmm... I'd be wary of running motor oil for extended periods of time in a gearbox; gear oils have additives to help them avoid shearing between gear teeth and stuff like that.
40-weight motor oil is actually similar in viscosity, I think, to 75W90 gear oil. Maybe a little thicker, actually. Gear oils and motor oils are measured on different viscosity scales:
http://www.irvingoilco.com/images/viscosity.gif
