Sti timingbelt for Legacy?
Crusher
Post by Crusher »
Hi all.
Anyone know about a Sti timingbelt for Legacy?
Anyone know if a timingbelt from a Impreza would work? I´ve found this: http://mastrowrx.com/index.asp?PageActi ... &ProdID=99
I really need a stronger timing belt than the stock and it would be great if I could get it inside EU. :)
1993 Legacy EJ20T Estate 5MT and some mods.
THAWA
Post by THAWA »
It should work assuming you've got DOHC heads. But don't blame me if you bend a valve :D
just kidding, I don't see why it wouldn't work, I assume the crank sprocket has the same amount of teeth on all ejseries engines. Otherwise I dont know how people put dohc heads on ej22t's.
Well, I can tell you that the factory service manual section for the 2002 US-market WRX timing belt replacement looks pretty much the same as that for the 1994 Japan-market WRX, including the tooth counts between marks and such.
So, I think that STi timing belt would fit your engine, since it fits the 2002 US-market WRX.
Crusher
Post by Crusher »
Sounds good. I´ll try it.
THAWA: Yes I have DOHC or should I say DDOHC :)
THAWA
Post by THAWA »
Whats DDOHC?
Dual dual overhead cams maybe? Since there's two pairs of camshafts?
Matt Monson
Post by Matt Monson »
Did it occur to anyone that he could use an STi timing belt from an early WRX, like a v1 or v2?
Also,
Why on earth would you need a "stronger" timing belt? this just do not make sense. The only thing I can think of is you are running both a lightweight underdriven pulley and a superlight weight flywheel and are having problems? Read this, if that is your set up:
http://www.spdusa.com/pulley_kit.htm
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
I think the question was whether the "new" and "old" STi timing belts were the same.
From what I gather, the purpose of the stronger STi cambelt is to avoid the situation where excessive torque at the crank causes the belt to stretch slightly, which slightly changes valve timing in an unpredictable way.
NICO
Post by NICO »
i am with vrg3 on this one just change the belt sooner, if you can break your belt then you must have some series problems or your makeing 2000hp, my car is fast and i got 600thousand ks and i have never had this happen.
Crusher
Post by Crusher »
Ok, if you say so. I´m just so afraid that when I´m going over 16psi then things will break and when the timingbelt goes then it´s not going to be cheap to replace everything, so putting a STi belt would make me sleep better at night :)
THAWA: yep, 4 cams there is.
aspect
Post by aspect »
well, there's not really THAT much load on the belt...it doesn't drive anything but the cams...
dirt-covered 91 SS prorally
pat richard roll cage, DMS 50mm, stickers...
SOLD :(
99 impreza RS
ver. 7 sti swap, ver. 6 RA suspension, JDM bodywork, rotated GT28rs
THAWA
Post by THAWA »
and the waterpump :D
Crusher
Post by Crusher »
Hmm.. ok guys but if it isn´t so much load on the belt then why is there a stronger one for sale? ;)
THAWA
Post by THAWA »
probably the same reason there's all that other sti stuff for sale, like the radiator cap, engine and tranny mounts etc. Sure they help a lil bit but I dont think anyone is getting more torque or hp from a stiffer tranny mount :)
THAWA
Post by THAWA »
hmm, that's nt really what i meant, lemme rephrase that, I don't think anyone would say sti mounts are vital at high hp/tq levels, knwo what I mean. Like the stock stuff is more than good enough but sti is better sort of thing.
Brat4by4
Stratified
Post by Brat4by4 »
I'm sorry, but you have no idea what the heck you are talking about Thawa. The engine and tranny mounts take lots of twisting motion (aka torque). The more power you have the more twist and pitching. Once your engine and tranny start twisting stuff comes out of line... like the engine, gear box and driveshaft. Steeper angles on driveline stuff doesn't help anything... including horsepower. You must have never felt a stock tranny mount, it's like foam next to a STi mount. I could see my shifter move up and down and side to side under changing amounts of power and had serious gear issues with stock mounts. After I had those changed, my tranny issues pretty much went away and my car felt ridiculously better, went faster, and shifted quicker.
STi makes their stuff for a reason (unless it's a keychain). The reason for the heavy duty timing belt, I don't know. If it's Group N, it's probably for rally racers and much harsher conditions for the belt. If it's Spec-C then it helps you get more performance safely out of your everyday driven car.
Crusher
Post by Crusher »
Mhm.. Well that´s why I want a stronger belt, safety, I drive my car pretty hard and I don´t want to change the belt so often to be on the safe side and the STi belt costs as much as a stock belt here in Sweden, that´s without the customs fee and postage so finding this belt and other fun stuff inside the EU would be fine. :)
NICO
Post by NICO »
maintain your factory parts change them more often, about the tranny mount change them more often as well.
brat4by4 when was the last time you changed your tranny mount, how many times do you change it in a year.
brat......I think you are the one who doesn't know what he's talking about....
I agree that yes there is a big difference between sti and non-sti engine & trans mounts.....I've felt them, and feel the difference every day i drive my car......
The timing belt on the other hand.....is an integral part of the engine.....would you seriously see subaru making a "softer" timing belt for the "street".......the timing belt felt pretty damn stiff and rigid to me....even the old one I took off after 60k miles.
IMO an sti t-belt is simply marking bull shit!
Brat4by4
Stratified
Post by Brat4by4 »
Like I said, as far as I know, STi doesn't make anything for marketing purposes unless it is on a shirt or ballcap. If it's Group-N it's for professional racing, not really for street cars. Of course some racing parts are overkill for the street. Don't forget that it is the VENDORS that market STi stuff to the customer, not STi itself. STi is not APC.
this is true........but I still don't think any of us need to worry about needing an sti t-belt......
I've heard of lots of people easily running stock belts for double the service interval, so I think they're pretty tough, but if they're the same price I can't see it hurting to use the STI one.
Crusher
Post by Crusher »
Yeah, the stock belt isn´t bad at all. I haven´t changed it for 160 000 Km(99400miles I think) hard driving *shame on me* and know that they really can take a beating. We´ll see what I find.
Aerotech
Post by Aerotech »
So what is the recomended change interval for the STI belt, and what is it for the stock BC-BF belt? I thought I read somewhere that the new cars had longer service intervals.....
Jerry
NICO
Post by NICO »
i had factory timeing belt on for 4 years and 400.thousand ks and i just changed it cuz i put new pistons in
