Hey guys here are the list of codes i got out of my ECU
14
15
16
17 all injectors what can possibly be wrong with all 4 injectors?
22 Knock sensor
23 Air flow sensor
31 Throttle sensor
42 Idle switch
45 Atmospheric pressure
sensor
Can All of this be wrong with my car how about when i drive it the engine light goes off and stays off and then when i stop the car and start it up again the light comes back on, could I have a loose wire???
Help
thanks
Neo http://bbs.legacycentral.org/images/smi ... lleyes.gif
Look At the codes I got
legacy92ej22t
I'd try to reset the ECU and drive around a little then repull the codes. Did the engine get wet or anything recently?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
nope the engine did not get wet, its just been like this for awhile. comes on and then off and then on and then off, on and off on and off
http://bbs.legacycentral.org/images/smi ... wisted.gif
petridish38
I would reset the ECU. Mine gave me codes like all 4 injectors and some other stuff, but once I reset it, only one code came back, and that was the problem.
Andrew
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
209,000 miles!
