does anyone know if anyone has a used lift kit for 90 or 93
legacy32656
Post by legacy32656 »
looking for a used lift kit or springs fo my 90 or 93 legacy wagons?? i have seen that there 400 new or so but im cheap.
let me know thanks brian
r0gu3
Post by r0gu3 »
Lift kit for a station wagon????
1992 Legacy Turbo
- Daily driver
1993 Montego Blue Touring
- Boost evading mod
legacy32656
yeah there both wagons any info????
Only lift kit I know of is the scorpion one www.isrperformance.com
Other option is try to buy some used springs/struts from a junkyard for an outback.
legacy32656
will any outback work??? and will i need the whole setup or just the springs??? will i need the out back top mounts or mine????
thanks
I don't personally know of anyone that has done this, but I don't see why any outback wouldn't work. You'd need the entire strut/spring setup. most junkyards will sell you the whole thing. Only other thing you'd want to make sure you have clearance for is the brake lines and ifyou got abs the tone sensor wires.
