What is the size of the bolt on the purge solenoid?
Is it 10 or 12?
I can't seem to get my wrench on it at all. I've tried for over 20 minutes today. I haven't yet gotten the wrench on it to get it to move.
-Ryan
-Ryan
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
I actully just did that aout a week ago, i dont recall the size but i can check that out for you later tonight. If you are using an extension to go under the manifold you need to either get a movable joint thing to rachet at an angle or get an extension with alot of play likon the socket end which would allow for a slight bend. its a pain in the ass to alight i recomment some needle nose pliers or something to hold it or you will mess up your fingers
Do you have a turbo? What did you have to do to unplug the electrical connector??????
That thing is burried down below the IAC valve.
2014 Volvo S60 T5
2014 Volvo S60 T5
I would guess try to push the safety with a screwdriver and pull the wires with something else. I know that seems sort of a caveman approach but im one to improvise with the little resources i have. getting the new one plugged in is another story. I can see how the turbo would get in the way but even mine without it i had to jam my fingers into the crevices between the manifolds. Maybe if your lucky you can find someone with small fingers.
I don't think I have the room to use a socket and ratchet. The intake of hte turbo is in the way.
2014 Volvo S60 T5
2014 Volvo S60 T5
if you take it off does it make for more room or is the actual compressor inlet right there?
Take the turbo off you mean? I sappose I COULDDD, but I don't want to.
If I really wanted room i'd take off the intake alltogether, but again, I'd rather not do that much work to change the stupid thing. Sapposedly it is possable without doing all that. I just couldn't get my wrench on to the bolt.
2014 Volvo S60 T5
2014 Volvo S60 T5
no not the turbo, just the rubber elbow and plastic intake parts right there. It's only two clamps and a couple hoses to remove right?
Oh, right. Well I probably will have to to get to the electrical connector, but the turbo is in the way of getting an extension and socket to the purge solenoid.
2014 Volvo S60 T5
2014 Volvo S60 T5
petridish38
