2.2L BLOCK VS 2.5L
kevin horonzy
2.2L BLOCK VS 2.5L
Are these the same blocks but w a bigger bore?
as for the open deck blocks, the 2.5 is broed and stroked
kevin horonzy
kevin horonzy
kevin horonzy
Which way would you go. I have only the block to take off the car this weekend.
My 95 has a air - air intercooler, garrett ball bearing turbo, msd ignition, thiel waste gate, blow off valve, bigger cat back exhaust, psi regulator, and fuel management on my non turbo for over a year. I want more then 8psi.
Since I have 130,000 miles on the car i would rebuild the engine.
I like the thought of the 2.5 turbo using all the other parts from this car. But when you factor in the 14 psi wouldn't the 2.0 turbo block be a better fit due to the size of my current fuel injectors and losey air flow?
Am I right in assuming the 2.0 turbo block will mate to the 2.2 na heads?
Can I use my 2.2 exhaust ducking on these egines.
greg donovan
2.2 n/a heads will fit i imagine turbo ones would too. but you will need to modify the headgasket so the water passages line up correctly. and i dont think it would be that bad of a performance combo as i am about to do this around the end of the month. but it will raise the cr a bit.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
