changed timming belt and is out of timing
nsantos23
Post by nsantos23 »
Hey Guys,
My timing belt poped yesterday due to a roller. Today after spending a few hours installing the new timing belt and aligning the timing marks of the camshafts and sproket, the car is awayyyy out of timing. what can i do to get it right?
thanks
neo
PS: by the way i got pictures of the procedure
1990 L 2wd 5spd 215K miles
THAWA
Post by THAWA »
how is the timing off if you lined up everythiung? can you go into more detail with what you mean?
Post by BAC5.2 »
Reset the ECU?
nsantos23
Post by nsantos23 »
i mean i ligned up all the marks of the valve shafts and main shaft and still out of timing, reseting the ECU will help?
mmm i may just have to take it to a shop tomorrow
Neo
THAWA
Post by THAWA »
I dont see how that's possible, did you use the arrows on the sprockets or the notches? How many teeth are between the pass side cam and the crank and betweenthe crank and the driver side cam?
nsantos23
Post by nsantos23 »
i used the notches
THAWA
Post by THAWA »
teeth?
petridish38
Post by petridish38 »
A shop probably wouldn't be able to find out what's wrong any easier than you could... just double check things.... make sure the belt is going through the pullies the right way.... make sure the marks are still lined up after tension is on the belt.... also... did you install the belt with the arrow in the proper rotation direction....and... did you line up the marks on the belt with the notches?
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
nsantos23
Post by nsantos23 »
thanks Josh
That was very helpful,
but i have another problem now, after everything back in place and the car running , i have a fuel cut at 3K rpm, it feels like the car is chocking , but if i give it gas it stops, changed spark plugs to NGks and changed the coil pack and nothing what can it be?
legacy92ej22t
Post by legacy92ej22t »
nsantos23 wrote: but i have another problem now, after everything back in place and the car running
What was the solution to the previous problem?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
nsantos23
Post by nsantos23 »
it may not have anything to do with it, but for some strange reason when the timing belt broke, 3 spark plugs stopped working, so when i put the timing belt on and tried to start the car it felt like it was out of timing but it really was misfiring!! well changed spark plugs to NGKs and is running fine except for the chocking at 3K rpm
cheers
Neo
Is it possible that your valve timing is still off by a tooth or so on one or both cams?
legacy92ej22t
3 bad plugs huh? Damn.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
THAWA
Post by THAWA »
what about your plug wires?
nsantos23
Post by nsantos23 »
yeah guys
this morning i went to start the car to go to work, and guess what it WONT START!!!!!!!! i'm getting furious, i'm begining to want to get rid of it! any suggestions?
thanks
NEo
THAWA
Post by THAWA »
sell it to me? :D but no, plug wires? ingnitor maybe? What about crank/cam sensors?
Matt Monson
Post by Matt Monson »
Neo,
I am so sorry to hear that you just have this extended string of bad luck. :(
I am going to guess that having the timing off for a few days has fouled up your new plugs. Pull them out and check them. A poorly tuned car can ruin plugs very very quickly...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
nsantos23
Post by nsantos23 »
m i dont know at this point, the plug wires and spark plugs are brand new just installed yesterday, the car was running fine yesterday after i got done with it, then i parked after test driving it and this morning it would not start.
I'm already thinking i should sell it to someone that will take care of it better, i would except any fair offer.
Neo
elkaboom
Post by elkaboom »
This is the 94 turbo you're refering to, correct? Where are you at (location, that is)?
Bob
90 Legacy LS AWD n/a -190,000 and going strong!
91 Legacy SS -currently stock and awaiting marginal upgrades (dead) RIP
nsantos23
Post by nsantos23 »
yes its the 94, i'm located in NJ why are u interested?
Neo, I really think you should take a look and make sure there are the correct number of belt teeth between the marks on the sprockets before you give up on the car.
nsantos23
Post by nsantos23 »
Dude, i have tried about 5 times taking everything apart and ligning up again and nothing my mechanic in which worked on a sunday just because of me took everything apart twice and put everything togther twice and it didnt happen i went over sensor by sensor with him (i always have 2 sets of sensors) and they all work fine, besides this even if i get the car running again i will sell it cuz gas prices here are ridiculous, $2.02 for super and the car only does 16-18mpg, so i really want to get a n/a legacy. Well if any of you are interested let meknow, any $1500 or so i'll let it go
Neo
THAWA
Post by THAWA »
I almost want to trade you my car (post tranny swap of course) :D
nsantos23
Post by nsantos23 »
well the car is 4 sale, and i just want to get it out of my hands, i'm on the process of buying a 95 LSi sedan, so price is reduced and i will let it go for $1000, i dont wanna know abou that car anymore, i've had enough!!
hehehe :x
Neo
