removing yellow from headlights questions
Gravija
Post by Gravija »
ive decided to clean out my headlights because they look covered in yellow gunk
how exactly do i remove the headlights? (or can i sand them and then clear coat while they still are on the car? [clear coating, i'd put newspaper or something around the rest of the hood])
i have 100, 300, 600 grit sandpaper, is this enough?
also, where can i find and what kind/brand of clear coat is ok to use on the headlights? ( http://kragen.com/PartDetails.asp?Sourc ... Code=3278D is that the right stuff for clear coat? )
and this should be done all while they are wet right?
thanks
92 legacy LS
plain and stock
162k
looking for mods
I wouldn't use the 100 or 300. It's too rough. I wouldn't use anything under 400. Make sure it's wet/dry sandpaper. and yes.....do everything while wet. Which is why it's easier to remove them from the car.
There should be some nuts behind the headlight which you remove to get the headlight out.
sullione
Post by sullione »
What about this flitz product? Anyone know anything about this?
www.flitz.com
James
1991 Legacy LSi sold!!!
2003 Infiniti G35
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
if you want to leave them on the car, there's a way to do it without sanding them that works, but i'm not sure how long they'll stay that way, as i had my headlights off about 4 months after doing the procedure so i just sanded and buffed them
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
