I have a 1991 LS Wagon with power windows. My rear passenger side rear window won't "roll-up" all the way (it is contacting the rubber seal, but not seated in the little slot at the top).
Can anyone explain how to adjust the height on power windows? Is there a pre-load adjustment behind the trim panel?
Window height adjustment?
I'm not sure what you mean by slot, but assume you've observed it not going as high up as the other windows. Sounds like a weak motor or bad contact. You could try checking for corrosion on the electrical contacts. Does it behave differently with the master or local switch? If you open the door and raise it does it go to full height?
Just tried raising the rear passenger window manually...it doesn't budge. Still about 1/8" below where the other rear window seats into the weatherstripping.
I'll likely be pulling the trim off this weekend to check things out. I did see this post when scanning the BBS for solutions to my problem...any idea what Andrew is talking about?
http://bbs.legacycentral.org/viewtopic. ... ht=preload
Thx,
Thx,
