Where to tap lighting for boost gauge
DeusExMachina
Post by DeusExMachina »
I'm mounting the boost gauge on the steering column of my 1991 Legacy Turbo. I want the backlight to be on only when the headlights are, and don't need any fancy dimming switch or anything.
Could I tap the power to the lead for the headlights on the lighting stalk's harness? I'm looking at page 18 in section 6 of the factory service manuals. It says continuity over wires c1, c2 and c3 for headlights, c1 and c2 for tail lights. Could I tap wire c3 for the boost gauge lighting and ground it somewhere?
Tap the illumination wire on one of the switches, ie cruise or rear defrost....or even run a wire over to the radio.
The backlight will go on when you turn your parking/acc lights on.
eastbaysubaru
Post by eastbaysubaru »
I hooked mine up to the illumination for the cigarette lighter. Very easy to get at.
-Brian
'04 PSM FXT
QuickDrive
Lurker-King
Post by QuickDrive »
I used the ashtray light to tap into.
R I P-------- 91 Turbo 4EAT --------R I P
