Mechanic says its OK
LegacyPunk
Post by LegacyPunk »
Well...my dad took my car up to a mechanic place to check out the Code 22, they recet it 3 times and inspected the engine well, and they couldn't find anything wrong with it. I guess my engine is running right even though the CEL is still on. :roll:
I noticed some rattling, at stops, of my IC against the firewall, might be affecting the knock sensor but i doubt it. ill put some padding on the IC and see if it helps, thats the only other thing I can think of.
Still sounds like I have some sort of boost leak, but could just be the MBC part throttle full boost thing, Ill pull the IC sometime and check the gaskets.
stupid knock sensor :roll: :roll:
:twisted::cool::twisted: "Plenty of time, to ruin my life, so why start now?" The Movie Life
1993 Sports Sedan, Exhaust, MBC, 02 WRX IC, KYB GR-2s...Now with old back seat!
Post by BAC5.2 »
You have intercooler gaskets?
LegacyPunk
Its the gaskets between the Y pipe pieces that connect to the back of the IC.
legacy92ej22t
Post by legacy92ej22t »
IIRC you're running an OEM MY02+ USDM WRX TMIC, correct?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
LegacyPunk
yes
It's not unreasonable to think that the intercooler banging around could cause the ECU to think it detects knock... I know a common way (at least in the past, when cast iron blocks were the norm) to test a knock sensor is to bang on the engine block with a hammer while it's idling. You supposedly can hear the timing retard happen.
LegacyPunk
Cool, well I turned my boost down about 1 psi, and now its back at stock boost and my boost leak seems to be gone. I don't know how this helped cause the air sounded like it was leaking past 5 psi, and now when i go past 5 psi it seems solid. Forked if I know whats goin on.
Ill throw some padding of some sort on the back of the IC where it touches the firewall and see if that helps.
