heater motor
Ian_D
heater motor
Post by Ian_D »
I need some help... My hearter/AC motor does not work
(at any of the power settings)
91 legacy 4 door sedan
Any tips/hints how to access and remove it
Thanks Ian :(
It's pretty much right there behind the glove box. If you remove the glove box, you should be able to see it and test to see if you have power going to it.
QuickDrive
Lurker-King
Post by QuickDrive »
Do a search, it may be several other problems besides the motor itself...
I had the same problem earlier in the spring, and somehow it just started working on its own again
R I P-------- 91 Turbo 4EAT --------R I P
