Mentioned wet/cold morning clutch shudder to the dealer at 12000km, and several times thereafter. This problem gradually became worse 'til the warranty repair was carried out at 52000km. Read about many possible reasons:
- moisture
- warped pressure plate
- throw bearing moving in the aluminum transmission housing
Much improved now that it is fixed. Here's the invoice listing:
LABOUR:
RE AND RE CLUTCH, ADD AWD, 97-2003 MODULE, RE AND RE RELEASE BEARING, ADD PRESSURE PLATE, JAB 26
PARTS:
USCI541002 BEARING DFAWFM2H3, U30539AA00 CLIP-CCH SLEEVE DFAWR3J1, U30502AA051 BRG-CLUTCH REL DFAWR3J1, USCI560001 REMAM CLUTCH ASS DFAWR11D
Question: Has the clutch been repaired properly?
Is 2002 LEGACY WAGON Clutch Shudder Fixed?
