Ventilator Problem
morgie
Ventilator Problem
Post by morgie »
New problem appeared today. My ventilator / AC / heater ... inside .... doesn't work at position 4 (max). it works at 1 - 2 - 3, but at 4, it stops, no air blowing.. :\
what can this be?
thanks!
morgie
'98 4Runner V6 Manual 4x4.
ciper
Post by ciper »
Isnt the fourth setting where the resistor is basically bypassed to allow full voltage to the fan? Id check the resistor unit first for continuity.
morgie
Post by morgie »
humm... ok... where is that ? haha :)
i'll go at my dealership to print the pages of the shop manual talking about that ;)
morgie
magicmike
Post by magicmike »
yeah what ciper said. I'd be willing to bet there is a problem with the switch not the resistor pack.
Mike
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
HomeSlice
Post by HomeSlice »
i got a gauge set for sale if it is the switch :)
MY93BC Legacy Sonora Sand---> black plasti-dip?
MY93GC Impreza Amethyst--> Glacier/aspen/pd White
93BC"edm" 93GC 90BC R.I.P.
Brat4by4
Stratified
Post by Brat4by4 »
The resistor dealio is behind the glove box I do believe. I've lost 1 and 2 on my Brat. I'll have to go replace that thing one day.
if it's the resistor pack it's usually the other way around 1,2,3 don't work while 4 does. You can try unplugging the resistor pack. If you still don't get anything for four, you can probably assume it's electrical and switch related.
