12 psi plus NA ecu = ACCKKKK!
douglas vincent
Post by douglas vincent »
Well, belt tension is a sloppy way of controlling max boost, but it does work.
I noticed that my boost had dropped from 8-10 to 4-5 so I tightened up the belt, and then went just a bit more for measure. I had to run an errand and on a section of highway of course floored it. Started knocking real bad so I started fluttering the clutch to see if it would go away but it wouldnt. Then I glanced down at the boost gauge.
12 psi!
I let go of the gas to say the least.
It turns out, and makes sense, that the higher the boost, the harder it is to turn the compressor. So while I may have been making 8-10 lbs of boost for the last 6 days, the belt was always slipping a little. So the moment I tightened it up to where it really should be ie no slipping, FULL boost occurred.
I think I will "detune" it by loosening the belt. Better low boost than blown engine. I get no knock at 5ish psi, sometimes knock at 10 psi. Full on knock at 12.
Please Santa, bring me an aftermarket ECU!
You can use the torque chip www.torquechip.com to add additional fuel and keep timing in check.
