I have a 98 Legacy AWD 2.2 liter. There is a small oil leak that appears to be coming near where the enigine block and tranny fit together. I cant find it and only leaks when the engine is running. It is burning off the exhaust. But not a lot of smoke just smells bad.
I am not the most knowledgeable with engines, but I do most of my own maintenance. Any suggestions? Where to look or start?
Ryan
98 Legacy 2.2 liter with....Small oil leak? Help...
98 Legacy 2.2 AWD
Rear crank seal shouldn't reach the exhaust. I think it's more likely the left rear cam seal.
