clunk...
magicmike
clunk...
Post by magicmike »
when I stop at a light or whatever then let off the brakes and slowly step on the gas I get a little moment of hesitation then a small small little clunk before the car starts moving. Seems like there is some play in the tranny somewhere. its an auto, any thoughts???
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
What happens if you go from driving slowly in reverse, stop, then to slowly forward and back again.....
Does the clunk happen each time you change direction? Does it feel/sound like it's coming from the rear of the car.
The front member of the rear subframe is known to do this if you're shiftin through the gears and on the power. However if the bushing's bad/loose. It may make the clunk.
tris91ricer
Title Whore
Post by tris91ricer »
well, start with the basics; if its in the rear, your diff needs to get looked at. Subaru rear diff failures are uncommon, from what i hear, so you should be ok, but check the play in your driveline. maybe your tranny mts need replacing? I've had this happen too, but it was the result of a broken LCA, which, you'd know was your problem.
When was the last time you serviced your 4eat? what 'bout the fluids?
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
magicmike
Post by magicmike »
Fluids are good. Service I have no idea. I found the car in a junk yard. I notice more of a time gap than an actual audible clunk sound. its not a bad clunk or anything. It just feels like there is alot of "slop" somewhere in there.
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
illnastyimpreza
Post by illnastyimpreza »
I have the same problem with my 91 L 4eat.
from a stop if I rev it a little to much it goes bang and surges forward.
I just go slow on the gass, then when it catches its usually ok. I'm guessing its the tranny itself.
It's all about the power to wait ratio
98 Impreza RS
91 Legacy L wagon
