Anyone here know what was the turbo on a JDM WRX 1997 ? (not Sti)
Thanx
97 WRX JDM turbo ?
97 WRX JDM turbo ?
morgie
'98 4Runner V6 Manual 4x4.
Yup, i found some infos on it, TD04L-13G
I Think someone here did the install in his LegT. will do a search to see if it's an easy replacement, and if it's a worty upgrade.TD04L-13G Stock Turbo Specifications (GC8 + GD)
Mitsubishi TD04L 6-style compressor wheel w/ 6-blade, 6-splitter design
40.56mm @ inducer
55.98mm @ exducer
Turbine Wheel - standard TD04; 12-blade design
46.88mm @ inducer
41.18mm @ exducer
A/R = 13mm = 0.51"
morgie
Its not a worthy upgrade, its too small for a 2.0ltr as it runs out of puff before redline, let alone for a 2.2ltr!
go for a JDM 94 - 96 WRX TD05 or the Aus spec RS VF12 turbo both are quite capable of holding 17psi to redline.
