I have recently purchased a Blitz VGTT (Voice Guided Turbo Timer). Needless to say that I got it used on eBay and obviously it didn't come with an installation manual.
I would really appreciate if all of you, who have installed turbo-timers in their Leggy's would take a look at the pictures below and help me decipher how I should hook this beast up.
Here are the pics:
...After countless hours of searching for a wiring diagram, I have been able to come up with an "approximate" wiring diagram based on the on the standard wire colors used in other turbo-timers (Like the HKS type0 and Apexi TT).
Please take a look at the wiring info below and let me know if it looks approximately like the wires in the turbo timers which you've had experience with:
* RED: 12v+ Constant
* BLACK: 12v- Ground
* GREEN: Ignition 1 Output
* BLUE: Ignition 2 Output
* PURPLE: Vehicle Speedometer Signal
* WHITE: HandBrake Switch?
* BROWN: Shift-Lock? (for cars with an Automatic Tranny?)
Last, but not least, I would be very greatful if you guys could help me out with wiring this turbo-timer up. Specifically, what I'm looking for are the colors and locations of the ignition, speed-signal and handbrake wires.
...actually, I think that I've already found the "Vehicle Speedometer Signal" wire on vrg3's ECU pinout diagram. I think that it's the "B58.11 VSS" wire on the following diagram:
http://www.graphics.cornell.edu/~v/ecupins/
The question that baffles me the most are the two "Ignition 1 Output & Ignition 2 Output" wires... where the heck do they go? Do our cars even have 2 Ignition wires, or is it only found in newer cars?
The last thing on my mind is: how do I get this Turbo-Timer to work correctly with my Clifford Matrix 3 alarm system. Of course I would like to hook it up in such a way that after I finish driving, I would take the key out of the ignition, the turbo-timer would keep the car running, I would arm the alarm system, lock the doors and after the turbo-timer shuts down the engine, the alarm system is still armed.
Any help would be greatly appreciated...
(I also wouldn't mind documenting this whole procedure and setting up a Turbo-Timer DYI site for the Legacy SS)
Thanks in advance!!!
Peter
(pcalak@uoguelph.ca)
