Sunroof won't open
J-MoNeY
Sunroof won't open
Post by J-MoNeY »
My sunroof is having problems. I'd say that .2% of the time it tries to open. Most of the time you push the button and nothing happens. Sometimes when you push it, it slides very slowly back but feels like it may get stuck. I have two ideas on this. Either the motor most be going out or the buttons and contacts in the thing are corroded and or broken. Any ideas and how would I go about changing the sun roof motor if I need one?
Second is the taillights. The bulbs are fine and yet I cannot get the reverse lights to come on ever. It there a fuse perhaps that controlls the lighting?
Thanks - Justin
edit by jason for more appropriate title-ing.
98 LGT
J-MoNeY
Post by J-MoNeY »
15 views and zero replies. Poor form.
98 LGT
-K-
Post by -K- »
My sunroof is about 50/50. I have to hit the roof to get it to work. My guess is the conectors are corroded because my sunroof leaks.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
greg donovan
Post by greg donovan »
is this happening all the time or just in the winter?
s there any noise from the motors at all when you push the buttons?
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
Lunatech
Post by Lunatech »
I'd check to make sure the back-up light switch is plugged in properly at the transmission. I've encountered this problem many times in the past. On two different occasions it turned out to be corrosion at the light socket, once I never did figure it out, but most of the time it just a matter of being sure everything is plugged in properly and clean at contact points.
As for the sunroof thing, beats me.
Robert,
Rio Red 1990 L sedan 5MT at least 302000 mi. and Spruce Pearl 1996 Wagon 4EAT 245000 mi.
georryan wrote:
Don't knock him for thinking outside of the box. At least he has been creative.
J-MoNeY
Post by J-MoNeY »
greg donovan wrote:is this happening all the time or just in the winter?
All the time and no sounds.
98 LGT
JasonGrahn
Re: Sunroof won't open
Post by JasonGrahn »
J-MoNeY wrote:Either the motor most be going out or the buttons and contacts in the thing are corroded and or broken. Any ideas and how would I go about changing the sun roof motor if I need one?
Have you pulled your sunroof assembly to see if there is something obstructing the path?
There is actually a reverse "switch" in your transmission. I'd check to see if one of the wires has left contact.
-Jason Grahn
