Headlights - 98 Legacy - Gumby question
zachres
Post by zachres »
An inexperieced question about removing my headlights:
Is there a retention clip of some sort holding the electrical plug in the bulb assembly?
My owners manual simply states that i should "detach the electrical connector from the bulb," but firm tugging doesn't seem to do the trick... I don't want to muscle it too hard and break it.
Is there a trick that I'm missing?
Zach
professor
Post by professor »
they are just stuck tight quite often...you need to pull pretty hard while rotating back and forth slightly, and it should come off. I had one stick so tight on a Honda that the bulb broke apart, no matter as I was replacing it anyway
There should be some kind of clip, yes, holding the connector to the bulb. There's a wedge-shaped detent on the 9007 bulb's base, and a clip on the connector fits over it. You'll need to pull that clip up with a screwdriver or your fingernail.
zachres
Post by zachres »
Cool,
Thanks for the responses.. as soon as it stops snowing, i'm gonna go outside and give it another shot.
Zach
professor
Post by professor »
I see now that the '98 changed over to the 9007, Legacy only but not Impreza.
I also noted when searching that many complain that said locking clip busts off easily, so be careful
