That little dash piece..
tris91ricer
Title Whore
Post by tris91ricer »
Okay, maybe Vikash can answer this, or some of you with catalogs of part descriptions and numbers.. but...
I need to replace the dash piece that's a little square just above the radio bezel. It sits flush with the rest of the black trim there, to the left of the HVAC controls, and i believe on some models, it may have held some kind of switch, although I'm not sure what.
I busted mine in my 91, and then later, with my 92, the dealer had wired up some cruise control dealie to it, and plasti-welded some cruise switch on it, ala-factory style..
Any help, guys?
I have a pic from 1stsubaruparts.com with numbers corresponding to dash pieces, so if it needs to be clarified, I can add that.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
Cliff2.2
Post by Cliff2.2 »
could you post a picture?
91White-T
Post by 91White-T »
From your description, that's the spot where the air suspension switch would go. Those pieces just pop out, I believe.
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
mikec
Post by mikec »
I've got one sitting here that I'm going to put a switch into, but there's no part number on it.
And yeah, its were the air suspension switch goes.
tris91ricer
Title Whore
okay! Air suspension it is! ..That sounds correct, anyhow. Sorry, Cliff, I don't have a picture of the real part, just a schematic of the area, and a paintbrush-job of red circling..
Now I just need to call the stealership! Thanks fellas!
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
is that the one you pop out and there's a screw behind it?
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
Yeah it's the blank that goes into the spot where the air suspension goes.
Just go to a junkyard, you're bound to find a legacy that still has that piece in there, or someone on the board might have one.
Anyway, the part # is 83003AA060
tris91ricer
Title Whore
That's awesome. Thanks Josh, for pimpin' my ride!
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
