but i need to know what rails they will fit in, i'm thinking 92-94 NA rails because they look alot like douglas's nissan injectors (they are 440cc iinjectors from a STi V6)
and will 92-94 NA rails (or whatever rails i need) fit on my 91 T-Legacy auto intake manifold?
thanks guys
As for the injectors, they do look close but with out actually holding them up side by side and/or trying them, I cant say.
See if you can test one of them out.
Disconect one of your injectors and try to plug it in.
Ive heard most side feeds will fit.
If thats not possible make sure you get a good picture of the plug and make sure they look the same.
If theyre resonably priced just buy em, you could always put them on ebay.
Good luck
Sam
well i am putting a fule rail and injectors for a sti on order, to me i think they will fit right in or what we could do is get sti ones and get longer bolts to hold the caps on so they stay in. no matter what there must be a mizx and match way for this to work.
give me a couple off days cuz, i am working on this and it will be done with bigger injectors cuz this time i am building a crazy EJ22Turbo impreza got the L modle got the parts just putting them toghether.
well guys i got my sti injectors in and they dont fit in my 1991 turbo legacy ej22t fule rails, i am just waitting for the fule rails to come in and will see if they bolt right up.
so far what i have done is the conectors that are use to plug in to my motor are the same, all you have to do is turn it around and it plugs in perfect to the sti ones. also we can still use your factory fule pressure regulater they are the same psi kp. all we have to do is use rubber fule hose to make everything work.
