ok this may be different for you in the U.S. but you may be able to help anyway i purchased a reman" front outboard CV joint for my 94 Legacy 2.0 N/A AWD but it seems to have 30 splines in the spider for the driveshaft where the orignal has 22 (so wont fit) what aplication is this joint for??? also dose anybody know if A WRX compleat shaft will fit (ie a shaft with inboard and outboard joints alreay on it) as i have been offered a pair
Any help woud be much appreciated many thanks
-Jp4-
Driveshafts
Are you sure it's for the front? I believe all of the new gen front axles with the exception of the usdm sti are essentially the same, spline/lengthwise anyway.
