ok... here is the setup
EJ22T with FMIC + Recirculating valve
Removed recirculating valve to shoot ether in the intake because it would not start on it's own. Still, the ether won't fire
The engine cranks no problem.
I checked the spark on one of the spark plugs, I have fire on at least 1 of the cylinders so that's not an issue. (I think)
I could not check the other because it was dark outside and I had no flashlight.
Even if there is no fuel going to the cylinders, it should at the very least fire the ether.
So, any opinions, toughts or tricks I could try?
