fogged/yellowed headlight lenses
Hi there, so I've read some mentions of wiping out lenses that are fogged (like mine are), but after I popped off those little snap clips, the lens didn't seem to want to come off.. and I didn't want to force it.. any ideas?
Thanks!
/Gus
Thanks!
/Gus
ex-devastated ex-owner of the $5500 parts car!
You shouldn't need to remove the lenses. The damage to the lens is typically just on the outside surface.
If you do want to remove the lens for whatever reason, though, you'll have to bake the headlamp to loosen the caulk attaching the lens to the housing.. Heat the oven up to 200 degrees, shut it off, and put the lamp in for maybe 10 or 15 minutes. Then slowly and gently wedge the lens away from the housing.
You clean the outside, not the inside, but i you wanted to take it apart, you can pop int in the oven for a few minutes on the lowest setting to soften the seal around the lens.
- Title Whore
Just in case you wanted it, here's the thread all about the de-yellowing..
http://bbs.legacycentral.org/viewtopic.php?t=739
I've found that not nearly so many steps are required. Just get yourself some #0000 Steel Wool and go at it with some kind of cleaner, or even water. Later, move to wax, and keep scrubbing 'til you get the results you want. You'll start to see the difference, and eventually, the lenses will *sparkle* again, and you'll know you're about done. Try using a combination of rounded and straight across strokes. I only spent about 10-20mins per light, and then shot 'em with a good douse of clear-coat, so the yellow won't come back.
You'll see fine again...
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
Thanks, Sleeper.. you live around SeaTac? I'll look for a badass legacy with pretty lamps next time I fly home
/G
/G
- Title Whore
I just want to note that pretty much all these methods will result in the yellowing coming back at some point. The clear coating is the only thing that will seal the plastic, and keep it from yellowing again.
- Title Whore
gotcha....I thought you guys were just cleaning and not clear coating.
- Title Whore
The fumes are the best part, maaaaaan!!!
I think I ended up using an inferior clear coat, though.. if you look at the lenses from an angle, they look yellowed again, at least they do on my 92s.. The 91s sparkled after I did 'em up. I was so jealous, but I needed them to go.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
