Here in Colorado our standard is 85 for regular, 87 for mid, and 91 for prem. I heard that you folks on the east coast have 87 as the base standard. I wonder why they have it this way?
It's not the boost as much as it is the air pressure, because not all cars are boosted. If I understand it right your 8:1 is less air pressure than our 8:1 at sea level. Sort of like us compressing 100 lbs of air to you compressing 90 lbs of air. Is that an accurate example or am I off base?
thats correct. on a NA engine, only so much of the atmosphere is sucked in on each intake stroke. since the atmosphere is less dense at higher altitude, less cylinder pressure is the result. octane rating refers to the resistance to detonation right? so with less cylinder pressure you are less prone to detonation, hence the lower octanes available.
We used to have 86 at Sunoco, but now the min is 87 and the max 94 (I think only at Sunoco again).
Ya, we have Ultra 94 here at Sunoco's but I have a station down the road that sells 116 Cam 2 race fuel. Only catch is that you have to put it in a gas can, they won't let you just fill up.
Down at Beaver Springs, local drag strip where the F&S and Shootout take place, they sell 104, 108 (both unleaded) 110, 112, 116 (leaded). They also sell naaaaawwss.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
I wonder what would happen if I ran half a tank of redline fuel treatment and the other half is seafoam.....You would be able to drink out of that engine...
