Canton racing products coolant tank 90.00
Radiator cap 5.00
3/8 T fitting 2.50
3/8 1/2' barb fitting 2.50
1/2 1/2' barb fitting 2.50
2 1/2 x 1/2 barb connector 2.00
3/8 x 3/8 connector .50
male x male check valve 19.00
6ft 3/8 hose 10.00
6ft 1/2 hose 13.00
$147.00
Yes i know this is more expensive then a stock replacement but my coolant gauge now rides just a little between halfway and cold rather then just above half as it used to. Now to install this you need a bigger place to mount it, I opted to get rid of my winshield fluid resivoir, which i will be relocating where my battery is at now. Also i do believe thier is enough room on the fire wall (mabey) if you dont have an intercooler. After driving around town for 45 min. temp gauge never even hit halfway, i am very please at what i have made...even though of the price. Thanks to VRG3 who helped me out with this, i am very pleased with the end result.
http://www.cantonracingproducts.com/tan ... aster.com/
Part number 80-200 coolant tank
Part number 7775k63 check valve
Custom Coolant tank works GREAT!!
92turbolegacy
1992 Legacy Sport Sedan
