I started my car today and the key fell right out of the ignition Then I had a little trouble getting it back in and turning. Then had problem restarting for a few secs and then it worked fine for the rest of the day..
Is the tumbler going or the switch or both.. How much would a used ignition cost?
Replace the key - it's likely worn out. More likely than the lock being worn out.
