Top feed fuel injector conversion?
Does anyone think it would be possible to convert our injector rails to a top feed system? Has anyone tried it? Is there any reason why this isn't possible? What would have to be changed? I'm assuming just the rails. Maybe the newer subaru rails could fit on there. Feedback
was that orignally a sidefeed setup? Where did you find that pic?
- Title Whore
From what I've seen there are two different types of manifolds, ones with a bolt pattern in a line, and one with offset bolt pattern. Whether all the inline patterns have the same spacing between the ports and the heads is another thing. Same with the offset patterns.
