Went out to PIR tonight and had a pretty good time. Other than the redicuously poor clutch action, the wagon ran close to perfect!
When the clutch would hook up, then i was able to get 15.2 - 15.4 times consistantly at about 88-89.95 mph. 7psi. And this was at incredibly low rpm launches. Like 3000 rpm.
I managed twice to get 2.05 second 0-60 times with the low rpm launches so I KNOW I can get high 14's if I were to replace the clutch. But that has to wait until I port my extra heads and get everything else ready to go.
Next time I will be shooting a little nitrous so even with the poor launches, i should be able to get 14.5 or less (cross you fingers!)
Stock my best time was 16.6 @ 79.
New all boost 1/4 mile time.
