Moderators: Helpinators , Moderators
dzx
Posts: 2711 Joined: Wed Aug 04, 2004 3:52 am
Post
by dzx » Thu Apr 14, 2005 3:24 am
Do you smell what the rock is cooking? Stage 1 regrind.
Should be interesting after i get the t3/t4 turbo on and the engine tuned.
///M
'93 Legacy SS - part out
THAWA
Posts: 6829 Joined: Thu Aug 21, 2003 7:44 pm
Post
by THAWA » Thu Apr 14, 2005 3:28 am
what were they reground to?
dzx
Post
by dzx » Thu Apr 14, 2005 3:59 am
nothing too drastic.
dzx on Thu Apr 14, 2005 4:16 am, edited 1 time in total.
///M
THAWA
Post
by THAWA » Thu Apr 14, 2005 4:14 am
no dice.
Posts: 9026 Joined: Thu Jan 29, 2004 8:47 pm
Post
by BAC5.2 » Thu Apr 14, 2005 4:44 am
What are those gonna do to the idle?
What is your engine management going to be?
dzx
Post
by dzx » Thu Apr 14, 2005 5:38 am
The grind isnt enough to really upset the idle and the stock ecu can handle the cams. But i have the Apexi ignition timing controller and the s-afc II.
///M
Post
by BAC5.2 » Thu Apr 14, 2005 6:27 am
Oh, right on. Thats sick!
How much, if you don't mind me asking?
THAWA
Post
by THAWA » Thu Apr 14, 2005 6:33 am
So the top numbers are the new cams and the bottom are the stock cams?
dzx
Post
by dzx » Thu Apr 14, 2005 1:06 pm
It was about 65 dollars a cam to have them reground. Once they got the cams, they had them for about a day then sent them back.
It looks like the bottom is the stock form and the top is the reground numbers. Not a big change at all but it's only supposed to be a 10% gain in power.
///M
Post
by BAC5.2 » Thu Apr 14, 2005 4:43 pm
Hmm, 10% eh? 21.5whp and 25.1lbft is a lot of power gain for $130.....
Posts: 9809 Joined: Mon Jun 16, 2003 11:20 pm
Post
by evolutionmovement » Thu Apr 14, 2005 10:06 pm
$65?!! Whoa. I wonder if they can use N/A cams to regrind to these specs ...
skid542
Posts: 2857 Joined: Fri Dec 26, 2003 6:37 am
Post
by skid542 » Thu Apr 14, 2005 11:36 pm
Wow a potential 10% increase, that's awesome for 130 bucks. I'm curious to see how it works out for you once you get it running again.
Lee
legacy92ej22t
Posts: 5203 Joined: Thu Nov 07, 2002 3:59 am
Post
by legacy92ej22t » Fri Apr 15, 2005 12:30 am
Hell ya, that's a big, power to wallet-weight ratio!
What management are you going to run with the T3/T4?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Post
by BAC5.2 » Fri Apr 15, 2005 5:47 am
There's a guy at my school running a T3/4 on his 2.5RS, and only made 176whp, and 160lb-ft.
I was pretty disappointed, so I hope you get some better figures out of it.
dzx
Post
by dzx » Fri Apr 15, 2005 6:41 am
I should, at least i hope so. The one i'm getting flows a little more than an 18G and a little less than a 20G with spool up around 2500 rpm.
///M
VRoman
Posts: 56 Joined: Tue Apr 19, 2005 4:47 am
Post
by VRoman » Thu Apr 21, 2005 12:11 am
evolutionmovement wrote: $65?!! Whoa. I wonder if they can use N/A cams to regrind to these specs ...
I'm ready to pay more than that, if I knew who can do same thing for a N/A engine.
Edit: I have a 94 Legacy 2.2L.
VRoman on Thu Apr 21, 2005 10:23 pm, edited 3 times in total.
dzx
Post
by dzx » Thu Apr 21, 2005 2:07 am
Have you called delta camshaft? They are located in Tacoma Washington. Good customer service. They probably would have something for n/a engines. I don't think the grinds are extremely vehicle specific. Kinda like HKS cams, they have a 626 and a 729 or something like that, i cant remember the numbers exactly but they use them for diff cars like supra, evo, wrx. I know cobb has some spicy cams for the 2.5 RS that matt monson has on his car.
Matt, if you read this, did you notice a difference when you put them in other than your dyno #'s?
Management is apexi s-afc II and apexi ITC (ignition timing controller) They've been laying in my room for a couple months now.
dzx on Thu Apr 21, 2005 2:15 am, edited 2 times in total.
///M
THAWA
Post
by THAWA » Thu Apr 21, 2005 2:13 am
What engine was he using though Phil? His stock one?
Post
by BAC5.2 » Thu Apr 21, 2005 7:12 pm
Hardy - Yea, it was a stock EJ25, slapped a T3/T4 on it and running 8psi. I was disappointed
Phil when he used to work at TurboXS, was at a wall of 390whp on his setup. No matter the tune, and TurboXS guys can TUNE, stuck. 2.5 block, 2.0L heads. Slapped a set of medium hot cams into the car and made 498whp. Then he blew the headgasket.
dzx
Post
by dzx » Fri Apr 22, 2005 1:16 am
They've had a lot of guys here blow the engine by using 2.0L heads with a 2.5L sti block. Jon says they replace more engine swaps because of that. He said why you shouldnt use the wrx heads on a 2.5L sti motor but i dont remember the reason. The most successful appear to be the 2.5 liter RS heads on the block.
///M
