Expansion Coolant Tank
nsantos23
Post by nsantos23 »
Alright guys,
i kept this to myself too long and its time to get it out there, i am making my own tank! well i bought the metal today and i am bending the metal tomorrow, ordering the filler neck on friday, welding sometime next week when i get all the parts together, thanks to my job i have a place to fabricate all this. as soon as i'm ready i will test it and let you all know how it goes. , suposelly it will be a stronger and heavier tank due to the material used. i guess all the engineering schooling is paying off now hehehe, yeah right. maybe if all works out i may accept orders.
Take care
Neo
1990 L 2wd 5spd 215K miles
Project_Legacy
Post by Project_Legacy »
kool. keep us posted eh? :D
00 5MT AWD 2.5 RS - New Project
Tleg93
Post by Tleg93 »
Right on, that's something I need to eliminate as a possible pain in the behind like Phil's episode that he had.
--Scott--
1991 - Rio Red SS
J-MoNeY
Post by J-MoNeY »
Oh crap. NSYNC's - Dirty Pop is on! Right on...
Anyways, I'd buy one of these bad boys just to have one laying around.
98 LGT
nsantos23
Post by nsantos23 »
hey all, the parts are cut and bent, lets see how the welding goes and the filler neck, hehehehehe, its coming along.
Project_Legacy
nice.
irishsetter
Post by irishsetter »
Great job just remember that there is a check valve on one of the lines to the expansion tank. Right now I can't recall which one.
nsantos23
Post by nsantos23 »
a check valve? on the ruber hoses? i dont think so, i never saw one
It's built into the 7.5mm hose barb that connects to the upper right corner of the radiator. It only allows flow into the tank.
nsantos23
Post by nsantos23 »
well i'm not changing anything as far as rerouting, i'm just making the tank. :roll:
Neo
nsantos23
Post by nsantos23 »
Welding begins tomorrow, it passed the strenght test!, it is bullet proof! I just ordered the filler necks, they'll get here on monday so this way i can weld them on to it next week and finally test it!!!!!!!!!!!!
I went trought 5 router table bits to cut this thing it weights about 4 pounds, and thats only for parts. after its welding proccess it may increase a couple of pounds.
I'm excited i'll keep you posted
Neo
Right...
The nipple on the stock tank contains a check valve.
nsantos23
Post by nsantos23 »
well iguess i will need to use a external check valve, or whoever buys it needs a external check valve, where could I get one of those?
Neo
nsantos23
Post by nsantos23 »
hey btw how big is that nipple again? all the nipple on my stock were replaced with metal and they are cracking again. so what are the sizes?
thanks for your help
Neo
McMaster carries a wide variety of check valves that you can page through in their online catalog.
nsantos23
Post by nsantos23 »
whats the website?
irishsetter
Usually any hose shop will have small check valves. That check valve is used to vent out any air that gets trapped in the top of the rad. I would just got to any local hose shop.
nsantos23
Post by nsantos23 »
ALRIGHT GOT EVERYTHING WELDED TODAY, GOT THE FILLER NECKS YESTERDAY, TOMORROW WILL BE A DAY TO LOOK FOR CHECK VALVES, THEN GET ALL THE ROUGH SPOTS OUT AND PAINT IT. HMMMMMMM I'M EXCITED!! THERE WAS EVEN BLOOD INVOLVED IN THIS, I BURNED MYSELF !!!!!! BADLY!!! SNIFFFF A HOT ROD THAT I FORGET THAT WAS HOT AND I WENT TO PICK IT UP, OPSSS GOT THE PALM OF MY HAD DEEPLY BURNED! WELL ITS WORTHED ALL THE EFFORT ITS ALMOST DONE, ABOUT A WEEK OR SO I SHOULD HAVE IT IN THE CAR AND TESTING.
I'LL KEEP YOU POSTED
NEO
J-MoNeY
Post by J-MoNeY »
OK!
98 LGT
