Engine Diagnosis
THAWA
Engine Diagnosis
Post by THAWA »
Alright here's the deal.
While the engine is cold, or still warming up there aren't any major sounds. Once it gets up to operating temperature I start to hear a BANG sound just about every revolution. I checked the FSM and it says if you hear a knocking once the engine is warmed up and idling to disconnect each injector one at a time. If it doesn't quiet the sound (which it doesn't) then there is something wrong in the heads. The three things it suggest is: really worn lifter, worn cam gear, or worn cam journal. Does anyone have any other ideas as to what the problem could be? I haven't tried listening with a stethescope or screwdriver or anything yet. Any suggestions on what else I should check?
J-MoNeY
Post by J-MoNeY »
Could you take a small sound clip of it?
98 LGT
scottzg
Re: Engine Diagnosis
Post by scottzg »
THAWA wrote:Any suggestions on what else I should check?
The price on some RS heads. It's begging for them.
Post by BAC5.2 »
Rod Knock?
professor
Post by professor »
rod knock should change cadence and severity when you remove spark (or fuel, as you have done)
I'll go for the busted lifter, if there is a huge gap that develops, the valve will get slapped pretty hard. Better to get in there before you trash the heads too
THAWA
Post by THAWA »
I suppose I can make a vid of it.
RS heads would be silly at this point.
It doesn't sound like rod knock.
Good to hear someone else thinks it's a head problem.
douglas vincent
Post by douglas vincent »
Get the hose out. Amazing how well it works on narrowing down the damaged area.
dzx
Post by dzx »
You can replace lifters fairly easily, I suggest using his ^ advice and figuring out where it is coming from then you can remove the valve covers and rocker assembly and examine the lifters to see if thats the problem,
///M
'93 Legacy SS - part out
