http://img203.echo.cx/my.php?image=s37000017zi.jpg
my grandpa halped me machine this thing and it turned out pretty nice -hopefully it works. I just took the A/C canister thingy from my impreza and granpa made the cap that threads onto the top of it. The one line will come from the valve covers, the other will come from the crank case. Then on the otherside a line will go to the intake venturi thing for some vacuum and the last line will go to the PCV valve as another source of vacuum. Then to empty the tank there is a stop-cock at the bottom of the can where it will feed via a tube either back into the pan or to a waste conatiner. BTW i have an AC compressor and the AC radiator thing from an impreza for sal. the radiator thing might be good for an air to water intercooler system.
home made catch can
