Gear box help, plz
khunsa
Gear box help, plz
Post by khunsa »
Hi, I need to put a new gearbox in my 89 rs legacy/liberty, and i was thinking about putting an sti gearbox in it, would it fit without any modification or hassel? Help would be appreciated! Cheers!
PS. Ill post the version sti it was off of, later.
I love a good long legacy!
THAWA
Post by THAWA »
Yes the version definately makes a difference. Assuming the final drive and everything is the same it'll pop right in no problem. If however the final drive is different you'll have to change the rear diff. As far as the actual mounting of it, it's all the same. I'm assuming this isnt a 6 speed.
khunsa
Post by khunsa »
Its a version 3 gearbox, Wot about the diff ratio for 89 rs legacy? IM told the sti gearbox is 4.444. CHeers!
greg donovan
Post by greg donovan »
if the STI box is indeed 4.44 you will need a rear diff that works w/it. the original diff is probably not a 4.44. it is probably a 3.90 or a 4.11.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
