I don't know what it's name is...
I saw a manual boost controller on Ebay a while ago, and could not buy it then.
Now that I am looking to buy one, I can't find the one I want.
I don't remember the name of it, but it was a 2 stage manual boost controller that had a fighter pilot cockpit switch that would switch between the two preset boost levels.
Anyone know who makes this?
[quote="Manarius "]Only flamers will get those. [/quote]
[quote="All_talk "]How many WHP will that give me? :)[/quote]
2010 Subaru Impreza 5mt 5 door
Thank you?
Now next question.
Do you believe it is worth it?
Is there another controller that allows me to switch between two preset boost levels at a better price?
Is there one that is a better quality?
Sorry that was more than one question.
Now next question.
You could get a used real EBC for not too much more than that. Look on ebay for a HKS EVC or GReddy Profec, I would never spend that much on a MBC, especially a turboXS one.
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
It's a really cool concept being able to switch between two boost levels. Leave it at stock for around town daily driving and just flick the switch for spirted drives or track time. I personally have better things to spend that kinda money on. I've heard you could make your own MBC for under $10. In terms of quality, I've heard Turbo XS makes good products but I'm not speaking from personal experience.snowboarded wrote:Thank you?
Now next question.
'06 Impreza 2.5i wagon
why not 2 cheap mbc's wired in parallel and a switch valve?Subaru_Nation555 wrote:It's a really cool concept being able to switch between two boost levels. Leave it at stock for around town daily driving and just flick the switch for spirted drives or track time. I personally have better things to spend that kinda money on. I've heard you could make your own MBC for under $10. In terms of quality, I've heard Turbo XS makes good products but I'm not speaking from personal experience.snowboarded wrote:Thank you?
Now next question.
I think Hallman makes one for about half the price. Hallman makes good boost controllers too.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
You don't even need a switch valve. You could just plumb the two MBCs in parallel and put a lever-operated ball valve in series with the lower-pressure one. When the valve is open, you should get the lower boost level. And when it's closed, you get the higher level. Five seconds under the hood to switch between the settings. Or route the hoses through the firewall and stick the valve on the dash somewhere.
Vikash, do you have a thread you already wrote up on this, or is this something you just now thought up?
If not, how would I put the two MBCs in parallel?
I am not that familiar with the installation of it.
I may have mentioned it in other threads... it's really pretty simple.
Connect a hose from the compressor outlet to a tee. Connect each of the other fittings on the tee to the inlet of a ball-and-spring MBC. Connect a ball valve in series with one of the MBCs. Then connect the outlet of the ball valve to the outlet of the other MBC with a tee, and connect the remaining fitting of the tee to the wastegate actuator.
I was planning to do something similar to this in the past (and still do, if I ever get around to it). My plan was a "3-stage" MBC using 2 MBCs, 2 boost control solenoids, a 3-way switch and lots of vacuum hose and tees and wiring.
Basically with my setup the settings were stock (or more precisely wastegate spring pressure which was stock on the RX for which I was designing this), low and high, where "low" and "high" are the two MBCs.
I actually have all the parts I'd need, too, except for 1 more MBC and the 3-way switch, I just haven't gotten around to actually building it yet.
Shane
2006 Subaru WRX TR
1989 Toyota MR2
2006 Subaru WRX TR
1989 Toyota MR2
- Spelling Nazi
Kids and toys. I couldn't stand not getting all the power and I can use my foot to control the boost.
The only good reason to do this is if you have to let a girl drive your car or you have two tunes, one for low boost and max MPG.
Don't spend money on that, you could hook up a easy one with one MBC, one pressure switch, one T, one bleeder type valve, and your stock BCS (boost control solenoid).
Run the lines like so: Turbo outlet to T. T to MBC. MBC to wastgate. Other T to BCS. BCS outlet to Bleeder Valve. Make sure to use a restrictor inline before the T.
Wire it so the when the pressure switch is on it will power your in cab switch. wire that to the BCS.
Set the MBC for your low boost setting. Then bleed off with the BCS open for high boost.
The BCS is a simple on/off device, just because the ECU cycles it doesn't mean it has to be used that way. I use the pressure switch so it's not on all the time because it might burn out.
This is not tested, just thought up reading this post.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
93 Sport Sedan, 5mt
Using the throttle to limit boost does mean that the boost is made less efficiently; it's better to make 6 psi and have no restriction at the throttle than to make 12 psi and have a 6 psi restriction at the throttle.
Wouldn't you want to use a microswitch on the throttle pedal or lever/cam rather than a pressure switch? It doesn't seem right to me to trigger higher boost based on lower boost.
