90 RS struts on a 90 Legacy?
Slick1100
Post by Slick1100 »
Will struts for a 90 RS fit on a 90 Legacy?
Rob
'98 Subaru Legacy Outback
'09 Toyota Prius
'07 Kawasaki KLR650
ciper
Post by ciper »
What is a 90 RS? The only vehicle I can think of close to that year and name would be an RX, and no they wouldnt fit.
Slick1100
Post by Slick1100 »
These are Boge struts, and they say they are for 1990-94 Subaru RS Coupe 4wd.
Rob
'09 Toyota Prius
'07 Kawasaki KLR650
Wasn't a Legacy RS with an EJ20 turbo sold in some markets from 1990-1994? With the same suspension setup as 92-94 USDM Legacy Turbos?
Slick1100
Post by Slick1100 »
OK, I think I may have found the answer. MRT lists an "RS" under the Legacy/Liberty items. It also refers to the Impreza section for several parts due to commonality. I'd say they're likely talking about the Impreza RS, but it's really a moot point. Parts from a 90-94 Legacy will fit the "RS" as well as the Impreza, and vice versa. My other parts sources only show the Impreza and WRX, and nothing for the RS, so it was very misleading. Thanks for the input though... kicked me in the right direction!
Rob
'09 Toyota Prius
'07 Kawasaki KLR650
Make sure you are talking about the correct RS!
There is an "old gen" subaru that had the RS badging.
The liberty/legacy overseas was badged with the RS
And finally we have the impreza RS in the states
I can see how this can be confusing ;)
